Internet vs reality
might tnt sunday if it dries up here, wifes not happy about spending mothers day at the track ,but i cant wait to see how my rejetted carb works out ill post times good or bad that will clear up this thread.
I thought I saw that you installed jet extensions, are you taking different jets with you also?
Lumpy Rutherford died that realy sucks remember the episode with his old jolopee and then wally bought one.
I'm not gonna get into all the drama.......but I think the jetting up will help with your next outing, hopefully Sunday. I understand the test and tune thing and the more passes the better. I think you'll get there in time. Good luck with it :thumleft:, you have a really nice car.
thanks shes really sounding good ill see how shes drinking at the top end gonna run pure race fuel
one trans rolled a lip seal...has been repaired and back in car...
other trans was removed because the car broke the driveshaft in 1st gear and the spraq has to be checked or it could explode the next time used...instead i installed a spare trans..and going thru the one that came out...as it has been in use in since 2007 now...everything looks good..just going to replace a few thrust washers...waiting on parts.
I do all my own transmissions....so yes..i screw up the one that rolled the lip seal....
Captain Kirk called Scotty...and said he needed warp factor 9.......
Is this thread about the "disrespect" you get for owning and loving your chevelle?
Sometimes this kinda mentality is really bizarre.
Owning a Mopar and a Chevelle = traitor?
Owning a Mopar and a Daewoo = perfectly acceptable?
