Intro to a port job
what valve grinder did you have? This one is a kwik way NSG model from around 1968 when Cedar Rapids machinery became Kwik way ...and went on to make a similar driver with a smoother rounder shell and angled snout , losing the previous manufacturers look. I figured that out last night after doing some reading and finding the instruction manual
SIOUX Grinder and Driver.
Mine is so old, i don't thing they even put a date of manufacture. and if they did it was long ago and rubbed off.
Now you can get a junk head and go Wild with some Crazy angles!!!
And one, that is just a test head,(junk head) you can mud it up and reshape to you harts content!!!
I wish my new house had more them 110v in the my little 2 car garage.
Flow bench just setting in the corner collecting dust.
No dryer plug either, huh?
I like my valvejobs like I like my bacon --crisp. Pan seared scallops too--crisp. J.Rob
The holder/arbor needs changed if more than .0015 worn inside. Pilots too, the wear stacks up
I'm feeling your pain on that one brother.... My old quik way stuff was just like that. I sold it to a guy buying stuff to take to south america.
I SCORED a full Sioux seat grinder set to replace it.
Cylinder Head Supply ...is often cheaper than Goodson.
True, the stones for one.
Mine has outdated size holders, no more stones available. No worries, I bought adapters they sell for that.. so I can use the newer 13/16 stuff..which I bought some of those too. Nickle chrome and some finish stones.
Most important is the seat. Grind just enough to clean up. Then adjust the position and width of the seat with the top and bottom cuts.
yup
agree
Mine is the old square drive, grinder/driver. And them grinders are heavy!!!!
Vary easy to let the grinder hang a little. Cauesing the square drive to put a in even load on stem/driver. By floating it. By rolling it a round(best I can describe)you can tell when you are putting it on a bind. Once I learned this, seats be come way better. Star drive grinder are way easier to us.
I cut the 45, top cut 30 for the 'valve' seat size, narrow the seat with the 60. Theres more than one way to skin a cat though.
a lot of places just touch the 45 on heads that aren't in too bad shape... or dealership work.
If you can get all those angles in there, you can then polish them off to a radius.
That was me branching. Lol. I like the idea of a radius under the seat I think Mopar used to sell some seats like that , I know somebody did or does still. When you bring the valve up 300 lift and you have that 30 and 15 it looks real nice against it. and I believe that picks it up there. Now back to that crisp top cut, the lip on the short side chamber, it gets in the way for milling! Lol you can knock that off, put the out a valve job lower and not lose and maybe gain in peak even. You'll never get a j head to sub 64cc with that 30* funnel at the top. Material permitting, I think the exhaust would do better lower too. Not buried/sunk, just with the material for the angles and where the spent naturally wants to go into the higher hole so to speak. Lol
Put a seat in and that lip becomes non existent, like my '70 for '71 j heads, they go up to 280's, seats on both,
On a small block, I use a 15 degree top cut for size, the rest is the same.
