Inverse radius cam lobe
James Clews
Australia
Forgive my ignorance but can someone explain to me what an inverse radius cam lobe is?
With that much change in momentum on the lifter, youll probably need some very good springs.
You need LESS spring
1 inverse radius can give more reliability at the same area under the curve
or 2 the same reliability (springs etc)with more area
the ir gives the designer time to set the valve down easy with less chance of bounce
or 3 more effection duratio and area ith same seat timing
for street pick 1
