More specifically, will a standard shift flywheel off a 1972 340 work on a 360? Is the balance the same?
Ah thanks.I've not used that B&M part number beforeNo the B&M 10236 is not compatible for the external balance 340, the unit you should look at is #10235
B&M Flexplates 10235
