I'd venture a guess that since you don't need heat and a press to install floating pins, you could say they facilitate ease of assembly.
Sounds like an advantage to me, lol.
What I would like to know, is what POSSIBLE advantage you think you are gaining running "Steel on Steel" to Float a Rod ?You keep saying no advantage. Out of curiosity why did they make both pressed and floating to begin with?
so your concern is the pin getting tight in the rod hole or the pin wearing out the pin hole? thanks
