is it possible that these seats will fit in my 73 swinger??
pri_i_oh
73 dart swinger
NE Ohio
I have a 73 swinger. Is it possible that seats from a 72 Plymouth Satellite Sebring will fit? I really need front seats bad and I can get a beautifull front seat for 100.00 but I just dont think it will fit
if you can fit seats in the car you can make them work somehow. i once put mustang high back buckets in a 72 dart, took a bench seat out. had to have brackets made to bolt them in. also put a ford fairmont bench in a 67 cuda in place of buckets..at least you are staying mopar.
72 A-body white 71 B-body black.
72 A body
71 B-body
The seats, in general are the same. The mounting brackets are different. You can make them work, but they won't be a simple bolt-in.
Seats themselves are same width, track spacing front/rear same, track spacing on B-body is ~3" wider. This may hit the bump used for the bench seat bracket.. although the B track is a lot shorter on the outside edge than the A.
Both seats are P/S.
Grant
just so you guys know were talking about a bench seat.....still gonna fit ya think?
