440seven
Trying to make the decision. About to stuff my 440 in a 72 duster. Is it possible to run 17x8's with a low profile tire under fender wells? I've seen a few folks running them but unsure of what headers.
Yes I currently have fenderwells, but not installed (haven't swapped the motor yet). Hmmm I've seen a post or two of folks saying they've ran a 17x8 with a 235/45 but haven't seen what they've done to get there, or if it's total bs.
Yea that's what I needed. I've seen folks running 7's up front and and 9-11's out back. I'm assuming to run 11 rear springs need moving inboard? I think your right, I'd be probably be more than happy with a 215 or 225 up front.Yeah but if you're going to run 235's you might as well run 17x7's. Way easier to work out the clearances too. Even most 245/45/17's will fit on 17x7.5's, some even list a 17x7" as the minimum depending on the tire manufacturer. A 17x8" with the 245/45/17 would be better for handling of course, but the minimum recommended rim width would be better if you're trying to make them work with fenderwell headers. For autoX of course the max rim width is better, but on the street you likely wouldn't notice the difference in handling. You would notice if they rubbed on the headers though!
