Got any video (or at least more detail!) of all that? I imagine it's a Chevrolet deal, but sounds like a war on wheels to me...
My car was heavy 3650 dry so I had steep gears 456-1. The higher the ratio the more heat it will make. I ran a 5000 tight on the street. Good trans cooler. The Higher the ratio the easier the car will pull . You'll need a engine that likes RPM's we normally shifted at 8000 - 8300,
It had seen up to 9300 Playing with it. Low to mid 10's through the mufflers with tailpipes. Playing lets do the twist on the stereo.
If you like RPM's 5000 stall is your daddy. 14000 rpms with a 636 on methanol. The music you would have to experience in the seat pulling 6 gears to appreciate.
My 340 cuda has a 8" stalls to 5500 4.10 with 28" tires. The j was in my hemi rr flashed to 5000, 30 inch tires 4.56. Another 340 I had with the j stalled at 4500 if I remember correctly 4.56 maybe 27" tires.what gears are you running 4.88's or lower ?
Interesting, who makes it ?
A variable stall is what I laughed at. He pictured a 4 speed.Interesting, who makes it ?
Uh, 636 c.c's. He didn't say "inches".Please post a video of 636” turning 14k.
LOl, , I didn't see the 4 sp patternA variable stall is what I laughed at. He pictured a 4 speed.![]()
Yeah the four speed knob was the giveaway , but....Interesting, who makes it ?
Keene-Bell switch pitch converter. Adapted from a Buick Dyna-Flow transmission. I like them, but it’s basically the father of the lockup converter. But, if someone would make new “switch pitch” converters for a lockup 904 or 727 (same mode of operation, only uses a variable pitch stator instead of a clutch) I’d be all for it.Yeah the four speed knob was the giveaway , but....
Buick ,in the sixties, had an electrically switchable stall speed converter for the 400 turbo. A friend put one in his 383 Vega. Nice and tight on the freeway, stalled almost 4000 at the flip of a switch. Wired it up to tighten up again in high gear. A great idea that disappeared for some unknown reason.
Good call. I was thinking 636 cube tooUh, 636 c.c's. He didn't say "inches".
Nasty bike for only 636ccGood call. I was thinking 636 cube too
....except a GER.Any converter is streetable........ if you can live with the slippage....... and have a big enough trans cooler.
If the car even moved after you installed one of those pieces of scrap metal, you were one of the lucky ones! I don’t even want to imagine what their whole “race” transmissions were like…....except a GER.
I drive mine back and forth to work, the stores, cruise nights and car shows. It is totally streetable for me, and yes I run a large trans cooler.If the definition of streetable is 'honest', then there is no 5000 stall c'ter that is streetable. A lot of slippage & heat generated below the stall speed. Quoted stall speeds are generic. The greater the tq produced by the engine, the higher the stall speed.
This just isn't true. You really need to read up on modern converter technology.If the definition of streetable is 'honest', then there is no 5000 stall c'ter that is streetable. A lot of slippage & heat generated below the stall speed. Quoted stall speeds are generic. The greater the tq produced by the engine, the higher the stall speed.
The "Switch-Pitch"!!! I couldn't recall if that was Olds or Buick....Yeah the four speed knob was the giveaway , but....
^^ This ^^ Years ago I bought a B&M "3500" rpm stall converter and put it behind a mild 440 in a 71 RR, it was pitiful. My current converter that flashes 5600 has way better street manners.This just isn't true. You really need to read up on modern converter technology.
I bet when the guy that had the idea for the wheel told his buddies, they all scolded him and told him it wouldn't work. Then proceeded to stick their heads back in the sand! LOL
