I think it was asked, but I didn't see an answer....Are you sure you have the correct short front hangers on the car ?....(not the longer B/E body ones)
Those springs look shot to me, as well.
When the spring loses arch, it gets longer, that is to say, the mounting eyes move apart from eachother, compared to their designed eye to eye distance. The design purpose of the rear hanger absorbs the springs lengthening and shortening during typical on road driving.
Yours are so flat, theyre really long.Or theyre just too long period. Post #16 shows it all. Sorry, they gotta come out.
Mine are the original '69 Hangars for the stock springs.
How about a link to this super easy fix?I searched on Google how to fix the springs. There is a video on YouTube of a guy doing it from Jantz Engineering. Super easy to do. Mopar guys are so used to having to spend money they forget ingenuity.
56" eye to eye. I haven't located a part number. Front mount is stock, as is rear mount.Take the time to answer the questions that have been ask of you. Then we can quit Guessing and get you pointed in the right directions.
#1 part number of each spring(this is necessary for a SS spring as there is a L and R spring)
#2 measure the distance between the front eye and the center pin bolt that hold all the springs together.
Now, sense i don't have these answer i will guess with all the rest of us.............
If you had a B/E body (non SS) spring in there it would push the shackle back like it is doing.
How ever, the tire wheel combo would be push back in the wheel well by 2".......i thing that would be vary noticeable.:scratch:
Which brings me back to guessing on question #1.......I don't thing a SS spring is going to go that flat............
Since it seems I will be buying new springs, which vehicle weight is recommended? What part number would it be on ebay? I usually order from there. I do not mind a rough ride on the street. Just want the best possible hook-up at the track.
I have done some significant weight reduction. The doors are gutted with Lexan. Fiberglass hood. Fiberglass bumpers. No heater or radio. No carpet. Front runners.The one's that are usually used are P3412002/P3412003, or the "002/003" springs as most people call them. They're recommended for a 3200lb vehicle weight. Maybe a little on the heavy side if you've done much weight reduction on the car, but they seem to get used the most for most A-bodies in street trim.
http://www.summitracing.com/parts/dcc-3412002/overview/
http://www.summitracing.com/parts/dcc-3412003/overview/
:happy1: I have done some significant weight reduction. The doors are gutted with Lexan. Fiberglass hood. Fiberglass bumpers. No heater or radio. No carpet. Front runners.
Well, the next set down is recommended for a 2800 lb car, P4120863/4120864. Which set exactly would be best for your application is probably a better question for an experienced drag racer, which I am not...
http://www.summitracing.com/search/brand/mopar-performance/product-line/mopar-performance-competition-leaf-springs/maximum-recommended-vehicle-weight-lbs/2-800-lbs?N=400172%2B303247%2B4294919798&autoview=SKU
Weigh your car first, but i bet its closer to 3200 then it is to 2800(aks 3200 pound car)
I also forgot the aluminum heads, manual aluminum box, headers and intake.
