MoparMark91
About to do it tomorrow and Ill report backDid you raise the idle or change the oil yet?
Inquiring minds want to know.
What post #2 says. I've never in my LIFE seen a spec given at idle. NEVER. That manual up there ^^^^ is the first time I've ever seen an idle spec and yours is WAY over that. If there's enough pressure to keep the light out, or push the needle up as high as yours, you're good. The spec is almost always given at 2000 RPM. You need not concern yourself with any other spec. Stop worrying about a problem you do not have.
Here specs from my factory 69 manual. I gotta say I never saw this before like Rusty said. Altho it doesnt give IDLE spec specifically it does spec 500 rpm and 1000 rpm. Looks like all sb for 69 are minimum 20 psi. I'll chk 67 manual also
Very interesting. Post #2 came from the 73 Chrylser manual.
Quality electric gauges can be accurate, they should be checked against a knowen good mechanical gauge. Where is the sending unit for the electric gauge installed?Sorry for not getting back to thi sooner, well so i took it out for a cruise and it still at idle is at the same oil pressure.....The pressure has been the same at idle, when i give it some more rpm it does raise up but then tops out at around 75 or so. It is a electric gauge and i have wondered if it is inaccurate. I got sidetracked with some things so i didnt get to check with my oil pressure kit or do the oil change. I do have 10w40 and 20w50, so i can choose which one to go with. hopefully on my next day off i can do some more and see if there is a difference. Now i am a bit worried about what you guys posted about at oil pressure at idle as it seems like its all over the place but im also going to say thats after warming up? Are electric gauges as accurate as mechanical?
At 1000 I want to say it's at about 30psi I'm not at home but Im pretty sure that's what it was, it rises right away with anyrpm given to it75 is the max it sould be able to pump.
Yes to be checked with the oil hot.
Change the oil.
What was the pressure at 1000 rpm?
The sending unit is installed next to the distributor, I have had it for a few years as well and at one point accidently had wires backwards on it, but it still managed to work which is weird. Also it's a marshall gauge? Are those any good? Debating on buying a mechanical stewart warner or auto meterQuality electric gauges can be accurate, they should be checked against a knowen good mechanical gauge. Where is the sending unit for the electric gauge installed?
Dont know of Marshall gaugesThe sending unit is installed next to the distributor, I have had it for a few years as well and at one point accidently had wires backwards on it, but it still managed to work which is weird. Also it's a marshall gauge? Are those any good? Debating on buying a mechanical stewart warner or auto meter
If you're showing 30 lb at 1000 RPM I don't see where you're having much of a problem.
Set your idle at 800 and see what you have. That cam you have needs more than 500rpm at idle.
What do you mean by that? Honestly I don't know what you mean? I have it set right now to 750 rpm idleI guess my next question is. Are you purposely trying to have a lobe go flat on that camshaft?
Forgive me for answeringWhat do you mean by that? Honestly I don't know what you mean? I have it set right now to 750 rpm idle
I never knew about that or at least thought about it, I even have a valley pan in it toForgive me for answering
Camshaft lobes are splash lubricated, the lower the rpm the less the splash.
This way you do a cam break in at higher rpm's
