ImperialCruiser
Can the early cast iron, short Ball and Trunion assembly be used with the aluminum OD 4-speed? Would the output shaft and cast iron housing properly bo:jocolor:lt to the OD case? I'm trying to use the stock driveshaft in my 64 Valiant. The early cast iron 4-speed fit fine. I have an OD trans and would rather graft the two into one than mess with the drive shaft. (I know, but I'm odd that way.)
