I noticed that the carb spacer looks different than the carb gasket. Does this make a difference where it mounts with regard to the "divider" in the plenum..?
Do I need to use the carb gasket on the spacer?
Under the spacer or under carb?
Does the spacer need to be "modified" to match the gasket?
Thanks Fabo!
Thanks Fabo!
