BillGrissom
I found a crack in my 64 manual box, on the bottom of the worm housing. It goes ~1/3 around. The photo shows it well because I shone a bright light along the surface. Not real visible otherwise, but you can catch a fingernail on it. The other lines that look like cracks aren't (just casting lines or scratches).
The second photo is the only clean photo I found of other boxes - sold on FABO in Oct 2010, and also from CA so little corrosion. I think I see a crack in about the same axial location, but you know how photos are (tried zooming and contrast but ??). That view is of the driver's side and my crack doesn't go quite that far.
Is this crack a problem? Anyone seen it before? I googled with no luck. Could it be from the factory casting or heat treating rather than from extreme steering forces? My car is a convertible, so I doubt it was used off-road or harshly. The gear box still had grease inside and seemed OK, I just removed it for refurb since doing the whole steering. I know many will say "don't re-use it", but do you know that your box isn't also cracked. Have you ever cleaned it this well?
