cudafish65
So you already have a hydraulic cam and pushrods with the 273 rockers?
I haven't officially bought anything yet, but if I'm gonna replace pushrods I'm just going to get a hydraulic cam and lifters
So help me out. You said you were picking up an Isky solid cam and lifters. I get that. If you already have 273 rockers, you have the hard part done. The E4 lashes at .015 as per my old catalog. It will be as quiet as some hydraulics.
I'd rather see you use the solid. Lashing valves is simple. Takes 15 minutes or less and most of the time it's just a check. I'm just not a fan of hydraulic anything. The factory went away from solids because it was cheaper to manufacture and assemble hydraulic engines.
Hope you rethink your situation. I much prefer a solid, especially something like you picked. It's easy on parts, lashes tight and will be relatively quiet.
