[WANTED] ISO 73-76 Duster Parts
73Duster
Northwest, Ohio
I am looking for the following parts. Any help would be greatly appreciated.
Pair of horns w/brackets, Hi and Low, in working condition and decent shape.
Blower motor resistor part# 2521409
Under dash a/c vent mounting bracket
Fender mounted turn signal bulb socket & wire harness. (I have turn signal housing and lens)
Following parts in the color blue (will consider other colors)
Drivers side plastic sail panel
Lower steering column cover
Do you happen to need a pop out quarter window? I think it's the driver's side.
I have the blower resistor. It appears to be in good shape & it ohm's out. $23+ $10 shipping from 19030. I can fit it in a small flat rate box with ample space to cushion it from any damage.
