shutudown4
Fellow big block a-body owners
I have a big block oil priming question
Used priming rod and lifters got oiled and eventually the oil gauge at the top rear of the block registered 80 lbs
Absolutely no oil reached the rocker shafts
The shafts were installed in the correct position according to the manual
I’ve done this several times previously w other big blocks
But now can’t remember
There are offset oil holes on the bottom of the shafts. There are at the 15 degree position away from the rocker shaft bolts and TOWARDS the outside of the head nearer to the valves
Should there be oil coming up to the shafts using just a drill motor?
Or does the engine need to be running to get the oil up to the top? The rebuilt motor will be started up soon
Shutudown4
Shutudown4
