Distributor is just sitting in right now, I have to grind a bit off the head to clear it, the instructions say that I was just hoping they were wrong. Ran the trans cooler lines for mock up, they seem to fit and clear everything ok, so just need to come up with a way to clip them somewhere. Had to get creative with hoses, and had to use the Dorman housing to make it all work for the upper. Lower is also a flex. Got tired of trying find molded hoses.. Getting closer. Any info on taking out throttle cable I would like some help because I am perplexed... comes off pedal easy, but the rest makes no sense to me. I have the Lokar setup to install, cable with the throttle pressure/kickdown dealio
