Corrupt_Reverend
'72 Dart 318, 904, stock ignition
Had my car die on the way to work yesterday. I thought I'd run out of gas, so I pushed to a gas station and filled up but now it seems that it's an ignition issue.
The car will fire while cranking, but quits when the key is in "run".
I checked for power at the ballast with a test light (with the key in "run" position) and I've got power. So I guess I can rule out the switch being the issue?
The coil has less than 100 miles on it and I haven't had any problems up until yesterday morning.
Any ideas on what to check next? I guess I'll pull the coil and have it tested but I don't think that's the problem.
Thanks in advance,
~Rev.
Thanks in advance,
~Rev.
