Ok...One thing I discovered while driving "IT" was it was shifting a bit quick, by that I mean at low speeds. It has a cable instead of linkage so I figure, no prob, check the slack.
So I checked and it seemed a bit much. So I make an adjustment. Now it's a bit to tight, as it's delaying the 2-3 shift (under mild acceleration) until I lift on the pedal.
Well, under WOT I expected to old a gear for quite some time. But it doesn't. Motor gets to about 4500 rpm and then the trans shifts. You would think that if it's holding in gear till I lift during mild acceleration it should hold when pegged.
So what's the deal? Why is it shifting at 4500? I can't tighten the cable any more and expect it to shift. As is, I need to loosen it back up a bit.
So what's the problem?
