My partner backed the Valiant out of the garage, and noticed that it imediately started running rough. He took an infra-red temperature sensor gun and discovered that the #1 cylinder's exhaust manifold runner was 150 degrees cooler that all the rest. He then pulled the rocker cover and saw that the #1 exhaust rocker arm's adjustment screw had backed completely out, which allowed the pushrod to fall out of the lifter. The lifter had bounced completely out of its bore and was lying on its side, above the lifter bore.
An examination of the pushrod and lifter face showed no damaage, but, we were lucky.
The question is, would it be possible to install some thin, correctly-sized jam nuts on the rocker arm's adjusting screws to make sure this doesn't happen again?
Has anyone ever seen this tried?
Any information will be appreciated...
Thanks in advance...
