[SOLD] Jaz Products 210-620-03 black Aluminum 20-Gallon Fuel Cell with 0-90 ohm Sender
cudajames
San Jose, CA
This is a 20 Gallon black aluminum fuel cell with a 90 ohm sending unit for street or strip.
• Item Weight – 23.4 pounds
• Product Dimensions – 24 x 20 x 10
• 20 Gallons
• 0-90 Ohm Sending Unit
• Fuel Cell Color : Black
• Manufactured from 5051 Aluminum and TIG-welded for maximum strength
Has less than 500 miles on it. Replaced because went to an EFI system
Retails for over $360.00
$200.00 or best offer - local pickup near San Jose (shipping could be discussed probably around $60 for US)
I am also selling a holley black electric fuel system
Both Jegs and Summit list the dimensions for that part number differently than you have. Could you confirm the dimensions? If they are 20x24x10 then I can use the cell, if they are 30x23x14.5 then its to tall for my setup.
Thanks, Bill
You are correct, I am seeing different measurements on different sites.
Let me measure when I get home
After measuring the cell it is 20 x 24 x 10. Sorry for the confusion. I can't believe I found wrong information on the Internet
I have a box that will work for shipping the fuel cell
The shipping cost would be $60 with the US
