Again you guys never fail to help. I appreciate all the knowledge of the guys on this site.
Video dangit! lolAgain you guys never fail to help. I appreciate all the knowledge of the guys on this site.
I don’t know how to upload a video.
A lift helps. I loose fit everything with clamps then tack weld it while in the car then bring it down and finish weld each seam while the exhaust system is on parts stands. A set of screw jacks are also handy. If you’re laying on your back it really makes it way more difficult. I just did the 3” TTI kit on Friday on my 71 Duster. Fit was perfect.
Looks great Jim, yeah I'll be on my back.
Hey Steve i found starting at the back and working forward was best but i had headers , in your case maybe put your manifold pipe on first then work from back to front but i'm not sure on that . another thing is dont put your clamps on to tight as to dent your pipe then its a ***** to get back apart if need be . i reccomend the band type clamps over the u type .
Summit Racing SUM-681250 Summit Racing™ Lap Joint Band Clamps | Summit RacingThanks Aron, I've read go back to front, especially due to the kit being a header back and running manifolds.
I hear ya on not tightening U clamps, I installed part of the system while engine was on run stand, now I can't get the prick apart lol. I'll look at band clamps. I've removed the old exhaust, but left the old hangers mounted to car for reference.
Do band clamps require different style hangers?
Thanks!
This is what i mean steve and there are other neat clamps that dont crush the pipe .
i'm not sure about different hangers there maybe some for those clamps i used the lap joints where i could and used the u clamps where the hangers hang . the lap joints are nice on the mufflers they should help if you need to change them . I also put anti sieze compound where all the pipes connect and mufflers .Thanks, I would imagine the hangers would be a different style?
