Joining the Elite! Bought a 4 speed last night
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
68 A833 :burnout:pics are on the way. Will need everything else (pedals, linkage, shifter, floor hump, etc)
Not sure how to tell what vehicle it came out of?
Welcome to the club!! Brewers performance should have quite a bit of what you need.
Trying to find as much stuff used as possible. Save some cash for the big items (clutch/flywheel)
Anybody know how to decode these to see what car it came out of?
So, did the PO say it was working when pulled? I highly recommend goin over the internals thoroughly by someone who knows. Some install it as is and find issues only to pull it out again. Very discouraging and a PITFA.
gears look good. having new seals and gaskets installed then in it going in
What are all the parts needed for the swap? I have been kicking around the idea of a 360 / 4 speed swap into my 74 6 banger swinger and I might start collecting parts over the winter.
skep, i have a hump, z bar, clutch rod to z-bar. ball stud and mount for the frame rail, stud that mounts to the trans.165.00 shipped to you
i do not at the moment, as they are all still in the demon
That's a late build '68 model A-body 4 speed for sure.
You can't tell which car it came out of unless you find the car with the serial number that matches the last digits on the vin on the tranny.
