OUTLAW
Master of All Mopars
Here is one I thought would be a simple fix. When running my volt guage will jump back and forth between 12 & 14 volts then steady and do it again continuously. Also with the lights on you can see them pulse up and down (headlights and dash lites both) .Thinking it was a brush bouncing in the alt or a diode failing I replaced the alt and voltage reg with new ones ( a total of 3 each) and it still does it. I have gone through the whole car checking and cleaning grounds and adding several extra grounds , and I have replaced the volt guage on the off chance it was bad. It keeps the battery up ok but just bugs the hell out of me. Also I have hooked up my Snap-on analog volt meter directly to the alt and it is steady. I assume it has some kind of damping built into it. Any ideas I missed?
thanks
EDIT: This is the old single field alt and mechanical voltage regulator if that helps
thanks
