jtkaaa07
BossMan
340's are a lot harder to come by, they ran 440's until I believe 77' so there is a pretty good supply of them out there
Anybody have any idea what a 440 is going for now days. I'm talking about the kind you find sitting in middle of a field not in a car or covered by any means. Went and talked to a mopar hoarder today and he says he would want a grand cash for a 440 without even knowing if I can bar the engine over or not. Pretty much the guy wants a grand cash in hand before letting in the field to check his pile of big blocks over. What would be a fair price now days?
Only if someone wanted one for a numbers matching car I would suppose, wouldn't matter to me, because you build it the way you want anyway.
Perfect example here:
"Very rare & Hard to find 440-mag Engine with a steel crank, out of an 1969 camper bus.
It still has the heads, valve covers,water pump, carb, exhaust pipe that I cut at the back of the block,
oil pan still on it, the freeze plugs are still in it!!
It was in a fire. but the engine block is good. this block is worth about $800 dollars!
so make me an offer, these blocks with the steel crank are VERY,VERY! RARE
I live 5 miles s/w of richmond mo. I could bring it to you, if you are not to far away
http://kansascity.craigslist.org/pts/4469955722.html
