Working on a 70 Dart. I am well familiar with 10 inch drum front drum and hub assemblies, and even aftermarket discs, but this is my first go with original K/H discs. Are the studs swedged in place like a drum and hub? If you have a hub without studs, new studs and a new rotor can this all just be pressed together or does the assembly need to be held together by swedging the studs (I know that this was just an assembly line thing for drums and you don't have to do that)???
