I need some help. I'm going to remove the k member in my Dart for clean up and Leana's powdercoating. Problem is, where do I start. In what order do I disassemble the front end. Thanks.
Sounds simple enough. Thanks! Can't wait to get to work on it
Be sure when she does her work that the holes were the pivot pin slides in is clean you do not want a build up of power coating in there.
Sorry, forgot to mention the engine is out of the car. Should make the job easier right? Everyone mentions taking the load off the T-Bars. Can't I just put the car on jack stands?
