[FOR SALE] KD_Tools Portable Ignition
MILO
Waterford,Pa
K-D tool # 2632 For starting older vehicles with points also GM HEI ignition. It will start a vehicle and get you home . Vehicles that have s bad coil points , condenser, wiring or key switch also with a click of the switch will work on GM Hei units that are inoperative. I kept this in my old vehicle in case of a breakdown I tested it and it works well.Located in Erie county Pa All the instructions are on the inside cover.$65.00 plus 14.00 to ship USA only Thanks
