fstfish66
kool site,, how do you find these sites???? what do you search????
daves66valiant said:I'm convinced now this will be the best route for me by far. The Mosher boyz are not too far down the road from Ventura. Very cool work they do for sure. I may call and check out if I can see their shop and the jig they use. From the pictures I see it is looks pretty easy lifting the car up with the engine hoist as they did, which is what I was originally thinking. I just didn't now how safe it would be until now. You guys should check out this link. Awesome pictures. SOme of the best I've ever seen.
-Thanks Clint for the link that helps tons
oldmoparsrule said:Hey Dave,
I am about 10 minutes from Moshers shop. If you make it down this way, send me an e-mail...I would not mind a trip over to see Moshers shop.
BTW, In looking at the jig they use to lift the chassis, it does not seem very difficult to weld up. Might be worth making something that would work...I am sure we could build it substantially cheaper than what someone quoted earlier in this thread...Besides, I need to get ready to weld up my upper control arms and need to dust off the cobwebs from the welder.
Thanks,
Clint S
San Gabriel
daves66valiant said:I'm about 50 miles north on the 101 fwy. I should be at the fling but I think my car will still be under construction at that time. I get dibs on the first keg stand if you stop by :headbang:
Dodgenut64 said:Looking at your pics so far, i think the shifter will come up through the console were the auto shifter did. Wont know for sure until i get some measurements. How far back from that little round tab in the tranny hump would you say the shifter comes up?
dart4forte said:We'll have to get together and share some ideas on our cars.
Dodgenut64 said:Just wondering do you already have a 4 speed car and switching to a 5 speed? if you had an auto, did you get the auto to manual conversion kit from Kiesler? If you have a manual set up now, what are you gonna do for the hydraulic clutch set up that comes with the TKO 5 speed? Will you be able to modify your 4 speed clutch pedal and stuff?
This thread will be the complete install eventuallyDodgenut64 said:so the clutch pedals from a 4 speed car will hook right up to the TKO stuff? Can you show a picture of how all this hooks up when you get that far, itll be very helpful , thanks.
I have the modified Lakewood that I got from Keisler. The picture is on my resto page.fstfish66 said:dave,, did you buy a scatter shield? or bell housing from them??? if you have a scatter shield,, did you have keislier modifiy it for the tranny bolt patteren,,?????? and if so could you e mail me a pic of it ?? thanks don [email protected]
lilcuda said:Dave,
I think you can get offset dowels from any Mopar Perf dealer, unless there is something special about the ones you're getting from Keisler. Also, I would recommend ditching the cheap non-hardened lockwashers on the flywheel bolts. They have a tendency to crack. Use blue loctite instead.
Lee
1966 Barracuda, 340 4 speed
Dodgenut64 said:Gotta say, Im a little lost. Ive never messed with hooking up a manual transmission before. What does this require? I thought it was a bit more simpler then this. Need more Innnnnnnnnnnput.
Thanks. It's really good practice for me since this is my first resto-mod project. Plus I have the pictures of each step to look back on for reference. Better to find out all the nuances now instead of later.fstfish66 said:DAVE... you are doing a great job,,,checking the run out just keeps thinks turning true,,,,what a shame you wil have to do all that cuting and metal fabing again,,but the end result will be great,,and well worth it,,kppe up the good work,, and great pics,,, im intrested to hear ,,about the clutch type,, and when you install the hyd bearing,,,,
