Kelsey Hayes SBP disc brake questions
Take a look at post #4.
I have hose brackets pictured were they go.
In the picture, i just use some bolts to keep things together, for picture taking purposes.
Well, you got it figured out.
Next issue is the brake hose. Dorman H71319 wont work as I have the star bracket in the wheel well.
Also I found out i have 70+ "D" shaped caliper house mount bracket...:BangHead:
Don't worry about the shape of the hose metal end.
Just stick it in the wheel well bracket and install the horse shoe clip to hold it down.
It will work ok.
Don't worry about it, loose any sleep over it.
You're the only one that's ever going to know.
Look at posting #23 again.
