[SOLD] Kelsey Hays 4 piston
Rbob
Olympia, Washington
Up for sale is Kelsey Hays 4-piston brake setup. Fits 67-72 A-bodies and is small bolt pattern. You can use Mustang Rotors if you want to go large bolt pattern. (use search function)
I can ship spindles, calipers, backing plates. Still assembled but will separate.
Shipping from 98584.
$200 plus the ride. May fit into 2 large flat rate box's
Accept pay-pal
not trying to hi-jack but i'm just curious here, I have this set up on my '71 swinger and you say you can use mustang rotors to go to large bolt pattern. what year mustang rotors would you use, which bearings would you use and can the ford rotors be used with the factory dodge calipers? thanks for any help.
