Will this work on 360 Magnum in an early a body?
Jake
Not sure if it will work in early A's but will not work with 360. I believe Magnum engines use same pan as LA360
I have one in my early A. You have to notch the K-frame to get the two front corners of the pan to clear.Correct. I missed the part where he said it was for a 360 motor. For the 360 you'd need the M302 pan, but I don't know about fitment in early cars.
Thanks for the info, ill just use a regular car pan.I have one in my early A. You have to notch the K-frame to get the two front corners of the pan to clear.
