Kevko oil pans
Alphabet Soup
Darlington Md'
Does anyone have experience with Kevko oil pans. I'm still working on a 360 for my buddies Scamp. I need an oil pan, as his is a little messed up.
I came across one on Marketplace that's for a 360 and looks pretty nice. The guy had it on a motor, but never in a car. Just wondering if any of you guys
could tell me any info. Thanks, Gene.
No experience here, but be sure and check for oil pump clearance. I bought a "stock like" Milodon, and that damn thing will not fit a high performance pump
I recently bought 3 Kevco pans, but only needed 2. I bought the wrong rear pan relief, which was for LA340's, 273's and 318's. The 360's and 5.9 & 5.2 Magnums use a slightly smaller rear pan relief, which leaves me with an unused Truck pan for a Dodge Dakota and an LA 340 etc.
Some have had k frame fitting problem with early pans and had to grind clearance with early pans, I have one on a 340 and it was very close getting .
I bought 2 and Both had issues with the end not made correctly. There were also other quality issues. So plan on doing some modifying for fitment
