Snake
Mopar Nut
This kick down was on my 318 2bb,B body Satellite different than the 1 I am used too.So will it work with a 4bb set up,or is there a way to mod it so it will work,trying to save on this build.Cheers.
I am keeping this one for sure,I got in **** from Cindy she said come on i would like a car for more than 1 year.This 1 is the best metal wise we have ever had.Sometimes answers come from within or require searching. If not here try google?
You keeping the Satellite of flipping it?
Do a search TONS of info on converting linkages/kickdown. 2bl can be modified
Edit.... I think Trailbeast modified his 2bl. Also 6pk2goDemon.
There is a 4 barrel end piece, slotted arm, that should all you need for that style.This kick down was on my 318 2bb,B body Satellite different than the 1 I am used too.So will it work with a 4bb set up,or is there a way to mod it so it will work,trying to save on this build.Cheers.
After taking a closer look,your right there is a slot for adjustment.When it comes time to slide the motor/ tranny in, I plan on playing with it.Good eye sir.There is a 4 barrel end piece, slotted arm, that should all you need for that style.
