VOETOM
One angle
Hmm, interesting.For sure the Holley bracket is needed and you may have to raise the manifold bracket to allow for the extra height caused by the Air Gap. We run the same setup on my brother in laws car and in fact, one of the images in my book is it.
Here is the four barrel lever and the two barrel lever and the only rods I have left
Is that rod the same as one of the rods you sent in the other image?
Mine looks damn near identical with similar weld.Poor weld job but it was hurried; you can see how much was added to fit the spacer and the Air Gap.
Wow. I just need to find pressure rod and should be smooth sailing. I am kind of surprised there aren't more aftermarket options. Probably because it is such a specific part.
