Hi everybody
I have a knok in my lower engine ( 69 B-Cuda, 1973 340 mild street build about 12-15 yrs ago). it started 2 (two) yrs ago. It sounded like the headers hitting the frame rails, so I never worried that much about it till now, but it is not hitting the frame rails. My son, and I checked it out yesterday, with a stethascope, and the only place we can hear, or get, the sound in the tscope is on the bottom of the oil pan. The headers are not hitting any where. The only time it knoks is at idle (850RPM). A little gas and 1000 RPM no knok. It runs great, and is quick, no driving noise at all. It has hydraulic lifters, not solids. It also has a windage tray. When idileing it does not jump all over, after it warms up it idels smooth.
So I am trying to figure out what it could be. I am leaning toward the windage tray or the oil pick up tube (its stock). One of the two might be making contact with the other. It "Ps" me off to have to pull the pan cause its super clean, no leaks.
I havn't taken a pan off a car for a while, Will I have any trouble taking it off,??. The FSM says to drop the center link. Also, whyle were at it, what are the best gaskets to remount it with.
Thanks for all the help, and suggestions.
Just an ole man asking.
barracudadave67
barracudadave67
