David Musselwhite
I have a set of brand new forged L2315 pistons for a .030 over bored 383 with pins. These have the fancy coated skirts and the 1.920 compression height. These will almost bring your 383 back to it's original intended high compression. These are higher compression then the silvolite, sealed power, and even the Keith black pistons. Can help get your engine block zero decked with just a couple thousands shaved off. Want a blown, nitrous 383 then you need these pistons. $325 shipped in the lower 48 states I'm in mt.pleasant sc
