Dragonbat13
After searching with no luck,
Will a Magnum timing cover work on an LA318 (roller cam TBI motor) with a LA318 center sump oil pan? That would allow the magnum serpentine setup.
I can find all the info in the world for everything else, but not for putting a magnum front end on an LA 318.
I have a 360 and a 318 center sump pan, and a couple of magnum camshafts which would get reground.
