63SplitWindow
Other than the cam and lifters, are there any other differences from the older LA blocks?
Well yeah. The main bore diameters from the 273, 318, 340 from the 360. Also the bore sizes. Some blocks have more meat than others in various places.Other than the cam and lifters, are there any other differences from the older LA blocks?
What block are you referring to? Roller LA? Magnum? Later model plain old LA? New Ritter blocks?Other than the cam and lifters, are there any other differences from the older LA blocks?
basically, I want to know which would be the better choice (if any) for a 360 stroker build
OK.....why?roller block
He answered that question.OK.....why?
ok.....thanks Professor"It's been said" that the early 360 blocks had more meat around the cylinders due to the factory still using 340 water jacket cores when they cast the 360 blocks the first couple years. More dimensionally stable, and possible bigger overbore- but you'd still need to have it checked to confirm a big bore.
Roller blocks, other than a slightly different valley configuration to accommodate the lifter retaining spider, also had taller lifter bores; which can be helpful in keeping some lifters from exposing their oil grooves with high lift cams or with some aftermarket retrofit roller lifters.
OK.....why?
I'm biased to old non roller 360. I have a 1975 360 block in my dart sport and it runs well. I make sure to use higher zinc oil to help cam survive. I like to keep all the drivetrain as it would be in its era. But everyone is open to their way of doing things too. I believe a non roller is just as good as a roller LA. I don't like magnum LA's because of the Chevy style rocker set up. I prefer shaft rockers.basically, I want to know which would be the better choice (if any) for a 360 stroker build
UnderstoodI'm biased to old non roller 360. I have a 1975 360 block in my dart sport and it runs well. I make sure to use higher zinc oil to help cam survive. I like to keep all the drivetrain as it would be in its era. But everyone is open to their way of doing things too. I believe a non roller is just as good as a roller LA. I don't like magnum LA's because of the Chevy style rocker set up. I prefer shaft rockers.
Any of the retrofit LA roller cams will work in the roller block, although with the factory retainer you are limited to factory-type hydraulic roller lifters. I am not aware of anybody making a solid roller lifter that works with the factory spider.Is there any availability issues with the choice of roller cams for the LA roller blocks?
magnum is a shorter deck height.I can’t 100% verify but magnum blocks are said to have a lower deck height spec. They have more meat in the pan rail as well. Not sure if those carry over to the roller LAs.
I never did a weight or cylinder wall thickness comparison with another block but when I built my 408 I used a 360 block dated march 73 and had it sonic tested and my machinist said it had some of the thickest cylinder walls he'd seen and he'd been testing them for 40 yrs. It's been over 12 years so I don't remember the exact thickness of the walls but he said if I had wanted to bore it .070 over (to use .030 over 340 pistons) it would've been fine. Since it wasn't a race application I just went .030 over. Hope this helpsHas anyone ever weighed the different LA blocks (preferably virgin) to perhaps get a hint of how much metal difference each has or have the resources? (early 360, late 360, '80s pre roller, roller blocks & Magnum) Add sonic testing the cylinder walls and a clearer picture may emerge. (Preferably with the same scale & test tools to eliminate calibration variances.)
