Thats a very STELLAR # for an LA indeedI got some pro-maxx heads going to the a porter soon...I will report the results but hoping to get them over 300cfm
Sounds good keep us updatedThe guy who is going to port the shockers has not looked at the heads yet...so I have no idea how much improvement ( if any ) can be made...I did purchase a few extra intake valves so that he could play with valve angles/cuts and see if there is any improvements to be found
Define best performing, as in what is the application? What works good in a Marine build may not in a mud truck.
It didThink the OP said 1/8 mile drag racing
Exactly lets find out !!So in the world of small block Mopar heads what is the highest flow number on record for a head without off setting the rockers?
I cant even find images of Airwolfs those must be some low production items and those flowed so well utilizing conventional LA rockers and not offset rockers ???Gun to my head, I would likely pick the reworked Bloomer heads now that Vic has redone them personally. The fact that he did them is all i need to know to place them at the top.
Second choice would be airwolfs. They went 3 mph faster than Trickflows did on back to back tests in very similar conditions on the same car a buddy has. Typical bracket type stroker deal
Ok kinda like Shadydell ???guy took Chinese eddie knockoff heads and made them 210 cc . He said they were 220, but they aren't that big. Yes, non offset.
His name was Dr J… he is still around, but there was some “ delivery issues” towards the end getting heads from him, and he pretty much evaporated…i heard he is out in California.
"Air Wolf" heads ... Vanished - Don Terrill’s Speed-Talk
AIR WOLF small block Mopar heads
I get that….so let’s compare apples to crab applesUnless the heads were flowed on the same bench the numbers would not be apples to apples
Thank uguy took Chinese eddie knockoff heads and made them 210 cc . He said they were 220, but they aren't that big. Yes, non offset.
Thank you - I guess without off-set rockers we are just limited to a few offerings and then have to rely on a few good porters to make them shine.Airwolves were nothing more than well ported pro comps. And promax I believe is just a rename of the defunct Patriot manufacturer that had so many problems they had to change their name please correct me if I'm wrong. And best is nothing more than a fallacy. Any of the major brands with factory rocker arm or pushrod locations can achieve similar results. There's no magic out there.
600 HP rangeI don't know what your goals are but a good set of ported edelbrocks, pro comps trick flows or promax can lay down some pretty impressive horsepower.imo oh yeah not to leave out J and x and some other production heads.
I wonder wonder why AFR doesn't make a high flowing LA head utilizing stock rocker setups ?
What is the absolutely best performing [LA CYL HEAD ] iron or alum MAX PORTED that DOES NOT use offset rocker arms ?
Asphalt 1/8 mile DRAG RACING
4 speed A body .
.Rules
SS rules
Only allowable heads with offset must be an oem
Like 340 style or my Mullin set ups
