[SOLD] LA Engine Spool Mounts
slant six
Do More With Less
IRWIN
one Set of spool Mounts
Asking $15 Plus Shipping from 15642- Cleaned and De Greased, ready for your project!
They were on a 318. Not sure what else they may or may not fit.
Thanks. They will fit 273 & 318’s.
340 & 360’s are wider on the drivers side by a little bit.
They’re still usable on the 360/340 with a little spacer to take up the slack. Washers work well. You would just need enough until you can’t get another one in the space. This way the bracket doesn’t bend when everything is tightened up.
Deal Pending with jhnycuda ....will see what happens.
If the part deal does not work out I will contact you Daniel.
Thanks!
