la/mag cam info
jazak5
NY
trying to gain some knowledge
acquired a TBI roller cam 360 la
will a magnum cam fit or somewhere I had seen a mention that the lifter bores are different? along with the fuel pump eccentric deleted ...
Besides a regind on my current cam are there other options and what is the durability/max out of spring pressures and lift on the factory roller lifters ? Motor had 87.000 miles on it prior to pulling it and it looks clean inside...
Will a magnum cam fit? Yes.
BUT
A Magnum cam uses a short nose that will not accept a fuel pump eccentric, unless you use the Hughes adaptor.
Magnum cams are designed for a 1.6 rocker ratio, LA cams are designed to use a 1.5 ratio. Use of a Magnum cam in your LA will alter the lift specs.
Lifters, and lifter bores, are identical between the LA rollers and the Magnums.
BUT
A Magnum cam uses a short nose that will not accept a fuel pump eccentric, unless you use the Huges adaptor.
my motor has the fuel block off plate/haven't removed it yet to see if there is a la cam in it ...
Roller LAs used a long-nose cam (at least every one that I've had apart). Some had an eccentric, others omitted the eccentric and just used a deeper cupped retaining washer; but are still able to take an eccentric.
All have had timing covers with the boss for a mechanical fuel pump, some used a block off plate, others did not have the center oval machined out (easily remedied).
Good to know...I have a 360 roller cam sitting in the box I want to have reground by Oregon (if they still do that) and slide it into a roller 318 block for my wife's '65 Dart. I know it will require some longer pushrods due to the reduced base circle, but that's easy enough...
