Lakewood 273-360 bell housing
prrc
Indiana
Lakewood Steel Bellhousing, Small block mopar to Tremic/TKO conversion Bell Housing. It is NEW in the original box. I have had this for several years and have never used it. 489.00 new I'm will to cut someone a deal at 300.00 plus shipping.
SFI-ApprovedYesBlock Plate IncludedYesBellhousing Bore Diameter (in)4.855 in.Bellhousing TypeNewClutch Fork IncludedNoAdjustable Fork Pivot RecommendedYesBellhousing MaterialSteelBellhousing FinishRed enamelQuantitySold individually.NotesDesigned for small block Mopar engines with a TKO transmission, this is not an OEM replacement bellhousing.
Lakewood safety bellhousings are designed for maximum performance and durability. They are cut on CNC 5 axis laser cutters rather than plasma cutters to improve finish quality, reduce heat damage and warpage from the plasma cutter, improve speed of manufacture, and make them all exactly the same. All bellhousings feature a scalloped plate on the bottom of the transmission surface made from G70 grade steel (70,000) psi which will help eliminate stripping the transmission bolts. The engine plates are made of H60 grade material and the bells are roto-brated after welding to relive any stresses created from the hydro forming, annealing, or welding process prior to machining and painting. The roto-brating process also closes the metal on the outer surface making them stronger. Ever wonder how the SFI tests bellhousings like these Lakewood safety bellhousings? First, they bolt the bellhousing to a machine with a cast iron flywheel and saw inside it. Then they spin the flywheel, causing the saw to cut through it until it explodes. If the bellhousing can contain the explosion, the bellhousing is approved. These safety bellhousings are a safeguard to minimize the destructive effects of such an explosion. Don't take unnecessary chances with your safety and the safety of innocent bystanders--Lakewood not only provides top-notch products, they also provide peace of mind.
