Nice!I have photo's on my old phone of the notched cylinders. It was done on a vertical mill. This is not a race car, so no time slips. Just a strong running street car that represents the early muscle car era!View attachment 1715406975
I've been working on this issue for the last year or so. With top ring locations being what they are typically, you're gonna be limited to the high 400's, or maybe right at .500" for max lift.
Roger.... The limit is the depth of the notch you can put in the side of the bore and not have the top ring get into the notch. If the notch can only be so deep due to that, then the lift can only be so much. I've been working on the premise to not allow the top ring to overlap even partially over the notch at TDC... sure wouldn't do the ring seal much good to allow it to do so!I’m def not following the reasoning here.
The piston is nowhere near TDC when the valve is at full lift.
Now I'M not following the reasoning here ???? (But hey, nothing new there!) The 273's 3.625" bore is so small that even with a 1.88 or 1.94 valve, that's gonna happen. That bore is smaller than the head chamber and you're gonna get this effect to some extent or another. Even 675 heads for the 273 and 318, does not change that; the chamber overhangs the deck. I would have to check to see if a 302 chamber did the same but I am pretty darned certain that it does.The 2.02 will cause reversion because of the air bouncing off of the deck. If u want a 273 to perform build it like the old D dart with a modern cam and 302 heads. Kim
But inquiring minds want to know ! LOLOh just notch the bore. It'll be fine! LOL
I remember the DDarts had late 50's Hemi valves. (Intake I think)
Apparently not. LOL I shouldn't believe what I read apparently. LOLR u sure about that Mike? Kim
I was just reading through this old thread. So very interesting. 1966 Dodge D/Dart ~ 'Mystery, Myth and Misconception'TMM - sorry about the X's.
D/Darts had stock 920 heads - 1.78 and 1.50 valves. They are closed chamber swirl port heads. Mine ran a best of 12.95 at 105 with launch and shifts up around 6900 RPM's. The Doug's headers had 1 3/4" primaries and 3" collectors back then. The guy that raced my first D/Dart used a 36" collector extension when he took it to the strip. I think he referred to it as a "stinger".
In the TSB D66-HP -1 dated April 18,1966, there is a section entitled `Car Operation For Best Performance '. This TSB can be found on the D/Dart website and the Hamtramck site.
Good question.If a larger than stock intake valve is installed in a stock 273 head....... what’s the lift point at which the valve contacts top of a 273 block?
