The tips are metric on newer Lincoln’s too.It is 1000 dollar welder for 700 I am thinking of tig for body patches
I used one 30 years ago in Ford Prototype welding mostly exhaust systems and built myself a stainless fuel tank for demolition derby. It is a more concentrated heat which I think would be better for body patches. I already have a mig welder and a spot welder.Never used a Tig.
You get less shrinking with tig but damn it’s slow.I used one 30 years ago in Ford Prototype welding mostly exhaust systems and built myself a stainless fuel tank for demolition derby. It is a more concentrated heat which I think would be better for body patches. I already have a mig welder and a spot welder.
Done lots of mig welding and spot welding and would like to try a tig welder.I used one 30 years ago in Ford Prototype welding mostly exhaust systems and built myself a stainless fuel tank for demolition derby. It is a more concentrated heat which I think would be better for body patches. I already have a mig welder and a spot welder.
Can you control the heat better and not blow a hole when welding sheet metal?You get less shrinking with tig but damn it’s slow.
I can’t. Lol.Can you control the heat better and not blow a hole when welding sheet metal?
I found when I used it 30 years ago with the pedal control I was pretty good at controlling heat and not blowing holes. I welded a filler neck section to the tank I made with no filler rod.Can you control the heat better and not blow a hole when welding sheet metal?
They make a controller that goes on the torch too. Water cooled torch would be nice.I found when I used it 30 years ago with the pedal control I was pretty good at controlling heat and not blowing holes. I welded a filler neck section to the tank I made with no filler rod.
never welded aluminum would be fun to try.I bought the tig for aluminum and S.S. I love it for aluminum. SS is kind of tricky. You gotta back flow it with argon.
To tig weld it it has to be clean clean did I say clean or it will blow a big hole fast.never welded aluminum would be fun to try.
Sounds good I'd like to try it. I'm not a good welder.I found when I used it 30 years ago with the pedal control I was pretty good at controlling heat and not blowing holes. I welded a filler neck section to the tank I made with no filler rod.
It’s a lot like O/Anever welded aluminum would be fun to try.
O/A ?It’s a lot like O/A
oxygen acetyleneO/A ?
I used a lot of O/A building door glass channels etc especially on antiquesoxygen acetylene
