BTW take pictures of the upper eccentrics and try to set the new ones there. It helps.
New eccentrics? I was planning on re using my existing ones. Ru referring to the upper cams that adjust the upper control arms? Im actually on the fence about the bac bergman arms.. they look rediculously easy to adjust and caster for days…BTW take pictures of the upper eccentrics and try to set the new ones there. It helps.
if they're in good condition, they're a-okay to reuse. inspect closely though, sometimes the cam plates like to waller out or the bolt shanks get ate up by rust.New eccentrics? I was planning on re using my existing ones. Ru referring to the upper cams that adjust the upper control arms?
I did pins first, and then found some black pipe that was the right diameter from home depot to go around the pin and push that assembly into the arm.I did bushing first then a stack of washers to keep the inner sleeve from being pushed out ,then the pin. I would imagine you could put the pin in the bushing first but then you'd need a tall tube/pipe and a proper sized washer with some strength, to go around the pin so you can press on the outer lip of the bushing. I dont actually know what the proper order is but I'd imagine both would work. And I do have a 67 and 68 service manual but as usual I don't have access to Miller tool C-whatever......
Thankshere's the link from summit
[/URL]
