I have a 64 GT Dart. I need new rear leafs. What will work on this car that you guys have used? I saw these HD springs from Mancini how much more than stock are they in stiffness, and how much more lift on the body? Anyone use them? I also saw super stock Mopar springs, but their description looks like something I dont want. So what is the difference? I just want to get the worn out stockers replaced, and if I get a little better control in turns and a little stiffer that is fine with in reason. I dont want it to drive like a truck. Also if it sits up to an inch higher than stock that is ok, I just dont want to lift it to much. I run 225x60x15s and they fit with the stock worn springs.
What would you guys use for a street strip car. I have front and rear sway bars better shocks poly bushings in frt end etc. Looking for better handling and want the car to sit not much more than the stock rake. Thanks! :salute:
Descriptdions I found.
MANCINI - (A-Body) Extra Heavy Duty Leaf Spring Set
Mancini Racing now offers replacement XHD springs for your Dodge or Plymouth A-Body. Bolt in a set today, designed for high performance A-Body cars. These springs have 1" added to stock arch to give more room for larger tires and better traction. Springs have front bushings installed. Springs are sold as sets only
MANCINI - A Body Pro/Stock Spring - 3000lbs.
Mancini Racing now offers Pro-Stock drag race leaf springs sets. These springs have 2" added to stock arch to give more room for larger tires and better traction. Springs have front bushing installed. Springs only sold in sets. Price includes a set of shackles or u-bolts.
