Leaf Spring Dimensions Station Wagons B
DieWilde13
Gifhorn/ Germany
Hey Guys,
i was wondering if the Leafsprings from a 1965 Coronet coupe and a Station wagon are the same in Dimensions?
I mean not how many leafs are in it, but the length.
Have a 1965 Station now and want to upgrade to S/S springs but want to be sure if they fit when i order a set.
Because nowhere is a special note for Stations or so.
Call either General Springs, Espo, or Springs and Things. I just did this for my 72 Coronet wagon and had to sort out size, length, and arch. I used General and was happy with their help.
Make sure you really want SS springs before ordering.
I had a 63 Dodge 330 wagon & bought & installed, with NO modifications to the wagon at all, a set of A-Body H.D. leaf springs. The center pin to front eye dimensions were exactly the same as were the pin to rear eyes. Early B-Body cars (62-65) should all be identical, wagon or Coupe/Sedan. (Same dimensions as 67 up A-Body's)
wagon leafs are the same.
62~63 are the same as A body, 64~65 are different the front segment is 1" longer and then 65~79(?) are 2" longer in the front and 1" longer in the back
SS springs are 1" longer in the rear segment
some SS springs require a different front hanger, so definitely check that out before splashing the cash.
