dragnknights
I aquired a 750cfm Holley Dbl pump. I put it on my car to see if it works, and after about 30 seconds of the car running. It started leaking out of the rear float bowl (or maybe between the metering block and the carb body) Anyways, is there any way to bench test these carbs for leaks before I put it back on the car?
Thanks in adavance for your help.
