swing69
fightin' socialism
THis is a chevy guy...but theory should be the same? if in a mopar, do you do the install the same way????????
I used dimmable uncoated peel and stick 5630 LED strip lighting. Eliminates light and dark spots in the backlighting. 5 meters of it is pretty cheap off ebay. You wont need much more than 3-4 foot of it. I soldered the end to a bulb socket, and plugged it in.
I was considering doing the same to the rear backup lights. They don't seem large enough to produce any usable light with old bulbs. There are so many LED light modules available. Although I haven't looked at the fixture to see how install would work, I'll post if I move forward with something
